TD40-Wd40
B Milne
05-14-2006 03:40:18
Found an engine out of a TD40 and would like to make up a WD40 with it instead. I read these engines didn't have serial numbers so it should look authentic. Anyone know any differences between the wheel and track engines?
Don Wadge
06-27-2006 10:54:19
 Re: TD40-Wd40 in reply to B Milne, 05-14-2006 03:40:18
Just browsing around and happened to see your post. I have a WD40 that someone put a gas engine in. I would sell it for $3500.00US if you're interested.
P Backus
05-14-2006 16:04:05
It"s been a while since I"ve researched it, but I know that the crawler motors had a different type of intake for the oil pump so it could work on steep inclines. Of course that won"t matter in a wheel tractor.
The thing is, as someone else said, to make it right it would have to be put with the WD-40 bellhousing, trans and rear end.
Good luck. I"ve always wanted either a TD-40 or a WD-40.
Paul
Fred Milner
05-14-2006 06:10:21
Sounds like a good project to me. I have a W 40 and need an oil pump for it if anyone has one just sitting around. You can email me at mmilner12@chartertn.net Thanks,Fred.
ihc49er
05-14-2006 05:50:00
The TD40 and WD40 are the same engine. yes it will fit right in the WD40 tractor . It will have a serial no. but not sure now if it matches tractor no. because later IHC made no attempt to match no.
n9lhm
05-14-2006 04:17:40
The W-40s and WD-40s have different transmissions (and bell housings too, I understand) because the gas 6-cylinder engine runs faster than the 4-cylinder diesel. I"ve heard that putting a diesel in a gas frame makes it travel extremely slow, but that it does have a lot of power. Brian P.S. If you know where there is an extra air cleaner for that tractor or engine I would be interested in hearing from you, since my PD-40 doesn"t have an air cleaner..... .
