300 Utility Ldr/Bkhoe
Tweeter
05-14-2006 18:30:29
There is an International 300 utility tractor about two miles from my house for sale. It has a loader (fully hydraulic) and a backhoe with extend-a-hoe. The steering is shot(manual) but it does run after tinkering with it. I have a 330 utility that i run right now with manual steering. Is this tractor worth anything? Is the loader and backhoe worth anything? Would the loader and backhoe mount right up to my 330U?
Szrachnor
05-14-2006 22:41:30
 Re: 300 Utility Ldr/Bkhoe in reply to Tweeter, 05-14-2006 18:30:29
I don't have all the specifics of your situation, but if both tractors are in equal condition and you can get the 300 to run reliably and you want a loader/backhoe, just put the 330 steering box on the 300. Easier then moving a backhoe and a loader, which would probably fit on the 330. The 300 also has a bigger engine (169 CID compared to 135 CID) and a slightly (and I mean slightly) larger running gear to handle the stress of the extra weight. You'll also end up with a spare set of tires and rims that interchange and some extra front end parts that could possibly interchange(depends if both are adjustable or non-adjustable type). And lastly, you could always repair or replace the broken steering box and have 2 tractors to drive around! Who wouldn't want to have 2 IH's to drive around??
Szrachnor
