A Charging Problems
Doug Wilkins
05-15-2006 06:11:05
Hey guys, Have a Farmall A with a brand new 6 volt battery. Went to start it yesterday and was dead. Jumped it and gauge was to the left in "discharge". I took the cover off of the regulator and tapped on the points causing the gauge to move over to "charge". I mowed for a couple hours last night, tried starting this morning and it cranked a few times and then was dead. Do I more than likely have a regulator problem? Any troubleshooting tips. thanks again guys
Marty Johns
05-19-2006 18:44:25
 Re: A Charging Problems in reply to Doug Wilkins, 05-15-2006 06:11:05
clean all connections 1st!!!!! ! IE emory paper, find grit sand paper,wire brush! then check all, B4 making a decision!!!!! !
Janicholson
05-15-2006 06:38:00
With a fully charged battery on the tractor but not connected to the Neg cable (best to charge it in this case with the Neg battery cable not connected), and all lights and ign off.
Using a volt meter, check between the Neg post on the bat and the Neg cables clamp. (hook the Neg black lead to the post, and red to the clamp)
If there is a reading more than .5 volts, there is a battery drain. This means the electrical system is leaking energy to system ground.
If no volts (good) connect the battery Neg cable and start the tractor. If it charges good, check the voltage across the battery. Black on Neg red on pos. It should be 7 to 7.2 volts. If so it is good. If not that high, thr regulator needs to be adjusted (old automechanics books, and repair manuals needed here).
If it does not charge, and tapping the regulator makes it do so, ai wouls replace the regulator.
To repair current leaks(as in the second paragraph), remove one wire at a time ,from the electrical connections in the box, and then on the regulator, to see if it stops the voltage flow. If that wire does not change the drain, re-attach it.
I hope this gives a starting point for your analysis.
JimN
Bob M
05-15-2006 06:21:03
Doug - The most likely culprit is the voltage regulator as you suspect.
Punch below for a troubleshooting chart. Follow it through and it should help you determine for sure.
