SMD sounds like John Deere - HELP!
AGR538
05-15-2006 06:41:51
When I bought the SMD, it was missing and the previous owner said it was a bad injector. I put in a rebuilt injector and still the same problem. This miss has a very distinctive popping noise. The noise is off and on but sounds like a cork popping out. It can be very loud. I fear my problem my be in the head but thought I would seek some advice before I pulled it. Any advice would be appreciated.
noncompos
05-15-2006 10:12:13
 Re: SMD sounds like John Deere - HELP! in reply to AGR538, 05-15-2006 06:41:51
With the utmost sympathy (and being the voice of sad experience) whenever a seller sez his whatever just has a minor problem, you need to ask yourself why he hasn"t spent the few dollars to get it fixed so he can get a much better price for smoothly running equipment...
the tractor vet
05-15-2006 09:49:26
Well , here are things to check . Pull the valve cover off and look for any valves that are not moving because of a broken push rod , broken rockerarm , broken valve spring . Stuck staring valve stuck down or broken staring valve spring . Now if you find nothing there then , i know you don"t want to here this but it is time to pull the head and look for burnt or broken valves . Now on them old diesels it gets even worse as it could be a cracked head or cracked block and they don"t always leak coolant just miss.
RustyFarmall
05-15-2006 08:24:36
I don't know a lot about those diesels, never worked on one, but it does sound to me like a valve, and it could be the compression release valves that are causing the problem. You might want to remove the valve cover and have a look.
EricB
05-15-2006 07:06:39
You probably need to do a compression test. Do both dry and wet.
1: Do a regular compression test.
2: Place a few ml of oil in each cylinder and do it again.
If you compression remains low on both tests its your valves. If it is higher on the second its your rings.
