farmall super a crank pulley
Matt DeGolier
05-15-2006 07:28:44
I am having diffacult time removing the crank pulley. I need to change the front seal in the timing cover. Any tricks out there?
Janicholson
05-16-2006 06:53:27
 Re: farmall super a crank pulley in reply to Matt DeGolier, 05-15-2006 07:28:44
There are a variety of puller plans and pics in the archives, A-B-C pulleys are pressed on and require good straight powerful pulling. JimN
Szrachnor
05-15-2006 09:05:49
The best way I've found to remove them without breaking the sheaves off is to use an OTC 938 17 1/2 Ton Push-Puller with either an OTC 1130 Bearing Splitter or an OTC 680 Pulley Puller.
Szrachnor
