Re: stalled international 300 utility
bob young
05-15-2006 07:51:18
how can i hand crank engine? because of my loader frame & cab frame, there is interference with my side access to fly wheel through starter hole and loader pump is operated off of front of engine. is there any other way to turn fly wheel or crank engine?
Janicholson
05-15-2006 10:50:50
 Re: stalled international 300 utility in reply to bob young, 05-15-2006 07:51:18
If you suspect the fuel lock problem, keeping the fuel from squirting out into a volitile mist is the key to safety. Putting a old cotton blanket over ths side of the engine where the plugs were will do it, just make sure the ignition is off. If the loader is on the ground jacking it up then blocking the arms to prevent it lowering will allow the tractor to be pushed in High gear. good luck.
JimN
