Re: stalled international 300 utility
Janicholson
05-15-2006 10:50:50
If you suspect the fuel lock problem, keeping the fuel from squirting out into a volitile mist is the key to safety. Putting a old cotton blanket over ths side of the engine where the plugs were will do it, just make sure the ignition is off. If the loader is on the ground jacking it up then blocking the arms to prevent it lowering will allow the tractor to be pushed in High gear. good luck.
JimN
