IH 786 electrical problem
Matt-NY
05-16-2006 12:12:45
I am trying to track down a problem with my 786 gauges not working. Has enyone ever noticed a small board screwed to the back of the gauge cluster that looks like 3 diodes attached to slide terminals? If so what are they for, they are broken apart and obviously not doing what they are suposed to.
Brownie 45
05-17-2006 03:42:09
 Re: IH 786 electrical problem in reply to Matt-NY, 05-16-2006 12:12:45
Wiyhout looking at a schematic, i would guess that they are zener diodes which are used for voltage regulation as Jim has said. If you can find correct values, they are readily available.
janicholson
05-16-2006 17:29:38
probably voltage adjustment resistors on an adjustable track to make the gauges read correctly. Probably not easy to substitute for.
JimN
