valve settings, head torque and loader of an H
Guyzoo
05-16-2006 17:47:38
Hi, I would like to know the torque of the engine head nuts and what is the valve setting when cold. Also Will a loader from an M fit on an H with no modification. THANKS A LOT!!!!!
gene bender
05-17-2006 03:59:10
 Re: valve settings, head torque and loader of an H in reply to Guyzoo, 05-16-2006 17:47:38
You should be able to measure the loader to see if it has enough adjustment to allow for the length and width of the frame.
CNKS
05-16-2006 19:30:53
Head bolt torque is 70 ft lbs, valves are 0.017 HOT. See the link, numbers agree with the factory manual.
River Bottom Farmer
05-16-2006 18:20:02
head bolt torque is 80 to 85 pounds and valve lash is 17 thousandths cold.retorque head bolts and readjust valves after running engine up to temp.Repeat this 3 to 4 times to get head properly torque down.....Hope this helps RBF
