230 hydraulic pump
Jason in SD
05-17-2006 11:47:20
I have a 230 farmall that the hydraulic pump is leaking. I looked over in the parts department and they have Hydraulic Lift Pump Repair Kit and a Hydraulic Lift Pump Overhaul Kit. What do I need to fix it? How difficult is this to fix? Can a novice mechanic fix it or should I have someone else do it? Thank you for the help!
El Toro
05-18-2006 04:20:56
 Re: 230 hydraulic pump in reply to Jason in SD, 05-17-2006 11:47:20
I have a parts breakdown on the Pesco hydraulic pump used on the Super A, Super C and C. Could be the same as the 230. I can send you a copy if you email me. Hal
