IH 674 3 pt not raising completely
dtucker21
05-17-2006 19:15:26
The three point on my tractor stop raising completely. It will come up about half way and stop. I had a 7ft brushhog on it and thought that it might be too much load and tried a blade with the same result. If the implement is in the raised position and I adjust the top link the arms move, as if they are compensating. I have had the seat and cover off to replace all the bushings on the shifter size and wonder if I may have screwed something up on the right hand side while working on it. Anyone have any ideas as to why the arms go up and down as they should but do not travel as far as they should, even without any load they do not come up all the way. This is a diesel, "78 model I believe. Thanks in advance!
FromJB2
05-17-2006 20:02:51
 Re: IH 674 3 pt not raising completely in reply to dtucker21, 05-17-2006 19:15:26
Hi, since you said "I adjust the top link the arms move", I would suspect something is wrong with the draft control linkage, adjustment since the draft control is sensed from the top link.
Good luck
JB2
dtucker21
05-18-2006 05:47:14
 Re: IH 674 3 pt not raising completely in reply to FromJB2, 05-17-2006 20:02:51
Is there anyway to disable the draft control? I onlt use the tractor as a utility and the only implements that I use are mowers and blades. Do you know where the adjustment is, internal or external? Thanks for the help so far, I am going to pull that manuals out and see if I can find a place to start.
wolfman
05-18-2006 17:38:23
 Re: IH 674 3 pt not raising completely in reply to dtucker21, 05-18-2006 05:47:14
I think there is a separate lever for the draft control sensitivity. Play with that lever & see what happens. My 664 won't let the 3-pt arms all the way down if the draft control lever is set a certain way.
