Diffrence in model C, FC and super C
Deere Heaven
05-18-2006 06:07:09
I have just been aquired a Farmall and the serial # plate says its a Farmall FC, is this odd. Most of the pictures are of just super C not FC. I will be selling it along with the cultivators, planters, and other misc Farmall pieces. Thanks, Brian
Randy in NE
05-19-2006 04:59:36
 Re: Diffrence in model C, FC and super C in reply to Deere Heaven , 05-18-2006 06:07:09
I dropped you an e-mail. Hope that you got it. If not my e-mail is uncovered. Randy
BillWV
05-18-2006 07:36:46
Super C's have a 6-digit serial number.
C: 501 - 71880
Super C: 100001 - 187788
From this site's Serial Number page.
Good luck,
Bill
Mark Peters
05-19-2006 14:20:37
 Re: Diffrence in model C, FC and super C in reply to BillWV, 05-18-2006 07:36:46
BillWV , Not trying to be a know it all , but the serial numbers you quoted aren`t exactly correct. The first number for both series is absolutely right, but the second number you list is the BEGINNING serial # of the C and Super C`s final production year. The last C was serial # 80432 and the last Super C was 198310.You have to look in the prodution #`s link on left side of the page.Just to clear up any confusion. Mark
Ron-MO
05-18-2006 06:48:33
CNKS is right. Both C and Super C used the FC prefix. Only the serial numbers can tell the story, except for certain differences in the pedals, grille (taller), etc. Even some of the late C's used the C123 engine (vs. C113 on most C's). Once you are aware of the differences it is not hard to visually identify a C from a Super C. There have been more than one Super C made from a C just by adding the stickers. Some put in the larger bore sleeves, and put Super C stickers on thinking that was the only difference when in reality the Super C was really a newer tractor and the C was no longer in production after sometime in 1951 (the C replaced the B in 1948 having the same 113 engine as the earlier A and B). Super C's were built until 1954 until the 200 replaced the Super C. 230's then replaced 200's, 240's replaced the 230, etc. I believe Super C's, 200, 230, and 240 all used the C123 engines. Or so it goes according to what I have found.
Red Dave
05-18-2006 08:36:44
 Re: Diffrence in model C, FC and super C in reply to Ron-MO, 05-18-2006 06:48:33
There's a lot more differences than just the bore size.
The grill is different
The radiator is different
The gas tank is different
The steering wheel is different
The brakes are different
The gearing is different
And that's just what I can think of off-hand, there is surely more.
BillWV
05-19-2006 06:21:14
 Re: Diffrence in model C, FC and super C in reply to Red Dave, 05-18-2006 08:36:44
According to some of the Super C advertising literature, several of the castings are stronger and heavier. Always wondered if that was really true.
When I was looking for my SC, I ran across several C's that were badged and advertised as Super C's. After a bit I could tell pretty quickly if it was a Super C or not. The one I ended up buying is a Super C that was advertised as a C. Fortunately, they had a picture with the ad. The Fast Hitch pretty much gave it away.
Also ran across a late C that looked just like a Super C. Apparently in the last few months of C production some (all?) of the changes were in place but they were still badged as C's.
Good luck,
Bill
CNKS
05-18-2006 14:57:18
No argument, but the gas tank is really not the same? I thought the grill was taller because of the taller radiator, thus the hood and gas tank are higher, but are the same as the C.
Randy in NE
05-19-2006 14:30:58
 Re: Diffrence in model C, FC and super C in reply to CNKS, 05-18-2006 14:57:18
The tanks have different part numbers but I don't believe there is much difference in appearance. Usually when someone says the tanks are different they are meaning that the C tank sits down on top of the touch control while the one on the Super C is about 3" above the Touch Control unit.
Red Dave
05-19-2006 17:21:41
 Re: Diffrence in model C, FC and super C in reply to Randy in NE, 05-19-2006 14:30:58
Like I said, "C and Super C gas tanks have different style mounting brackets underneath. Not interchangeable without a lot of modification."
Look at the bottoms.
Red Dave
05-19-2006 09:37:17
Mike ISW
05-18-2006 06:08:46
FC is the prefix for a straight C. Super C would be SC.
CNKS
05-18-2006 06:31:41
 Re: Diffrence in model C, FC and super C in reply to Mike ISW, 05-18-2006 06:08:46
Nope, FC is the prefix for both the C and Super C. Only when IH brought out the Super H and Super M, did they use the S.
Mike ISW
05-18-2006 06:57:10
 Re: Diffrence in model C, FC and super C in reply to CNKS, 05-18-2006 06:31:41
I stand corrected....ty
