Pics of turbos10's turbo Farmall M...
Steven@AZ
05-18-2006 19:57:11
third party image
third party image
As far as how to post pics on the forum, go here: HTML Basics: using images.
Chuck Joos
05-19-2006 18:54:18
 Re: Pics of turbos10's turbo Farmall M... in reply to Steven@AZ, 05-18-2006 19:57:11
With that setup you'll need a crank girdle to support the center main bearing or you'll pull the center main out of the block
Turbos10
05-20-2006 07:48:22
 Re: Pics of turbos10's turbo Farmall M... in reply to Chuck Joos, 05-19-2006 18:54:18
Thanks for the input, Chuck. I was thinking that a stud girdle would be a good idea, but I had not looked into who made one yet. I think it will be fine at low boost and lower RPM like I will pull it right now.
However, in the near future a girdle will be in order. Do you know of a good place to get a girdle and extended studs, or is that going to be something I just have to have a machine shop build up for me?
Any input on that would be very appreciated.
Levi K
05-19-2006 05:48:47
I... I... well... it's... WOW, That's about all I can say right now. It's VERY nice.
Jason Simmerman
05-19-2006 04:56:03
That's interesting. How much boost are you planning to add to it? Can't tell from the pictures but it appears you are running it nonintercooled correct? Still though interesting project.
Turbos10
05-19-2006 05:24:00
 Re: Pics of turbos10's turbo Farmall M... in reply to Jason Simmerman, 05-19-2006 04:56:03
Hehe...see that big black thing on the rear side of the engine? That is an intercooler from an 86 Thunderbird.
I am planning on running as much boost as it will possibly handle. I plan on running race fuel and injecting water in the near future. At first I will start pulling with the factory wastegate setting of 7-8psi. The compressor will comfortably run 30psi up to 3000 RPM on this engine. If I can make it hold together at that level, I will do it. That will put the engine around 275HP and 500lb/ft of torque. However, I have to get frame connectors and a scatter blanket before I start thinking about trying that RPM level. I dont want the flywheel to saw me or someone else in half if it decided to come loose or explode.
It is most likely that I will hold RPM to around 2500 and just concentrate on getting boost up to the high 20's or 30psi as the ultimate goal.
Someone mentioned RPM level, and I have that under control. I have a Mallory 3RLI ignition box going on the tractor, and it has a two stage rev limit setup. I am hoping to use the first to build boost before dropping the clutch and switch to a higher limit while pulling. I have to rig up a switch mechanism on the clutch or throttle to make that work. It will be later on after the bugs are worked out, of course.
Turbos10
05-19-2006 04:42:35
Thanks Steve for putting these up for me, and thanks guys for the kudos.
I will get a few more pics when I get the hood on and the wheels/tires on it. Hood fits over all this, BTW. I will also post some pics after I get the custom wide front, steering all that good stuff done. I plan on lowering the front end a little hence the turbo up pipe leaning back right now :).
John M
05-19-2006 03:01:25
Nice conversion to say the least! But I think Id put a tach on that thing to monitor the RPMS.With no governor,all that work will be for nothing.
Shaggy
05-18-2006 22:08:23
I want to take it for a for a little spin around town!! That is COOL!!
Shaggy
Szrachnor
05-18-2006 20:48:35
Oh my goodness....it's..... beautiful!
supermpuller
05-19-2006 16:14:43
 Re: Pics of turbos10's turbo Farmall M... in reply to Szrachnor, 05-18-2006 20:48:35
Nice looking set-up, you should be proud of your work.Its going to be interesting to see it pull.
Turbos10
05-19-2006 18:00:48
 Re: Pics of turbos10's turbo Farmall M... in reply to supermpuller, 05-19-2006 16:14:43
Thanks. I am pretty happy with it. I just got the fuel pump and filter on and it kindof uglied it up, but I can make some side panels to cover it. Inline EFI pumps are just not pretty.
I am very excited to see how it pulls. There are two pulls in a month, so we will see then.
