C stuck in Gear
jenglin
05-19-2006 07:10:16
My cousin was mowing with his C (w/ a 6ft belly mower on it) and he was shifting from 2nd to 3rd and the transmission got stuck b/w two gears. We pulled the shifter and we can see it stuck in the two gears but are unable to get the transmission into netural by moving the gears. Any suggestion on how to get it out of gear?
gene bender
05-19-2006 10:50:17
 Re: C stuck in Gear in reply to jenglin, 05-19-2006 07:10:16
Push the clutch in that will release the bind.
captaink
05-19-2006 08:11:03
If it is stuck in two gears (probably 1st and 3rd there can be a lot of pressure on them and that pressure makes it very difficult to get out of either gear. My suggestion is to find a long strong bar or something and have someone rock the tractor back and forth while you put pressure on the shift rail on the right side (3rd & 4th). The rocking hopefully will take enough pressure off so that you can get it out of one of the gears. The other will come a lot easier.
Then before you put the shifter back in have it built up so that it fits the rails tight. That way the chances of this happening again will be greatly diminished. Also stopping in neutral and making sure that you make a nice square shifting pattern will help, but that old habit of “rounding the corner” is hard to break
