F20 Valve Tappet
Tony (A2, MI)
05-19-2006 10:23:33
Hello,
I have my engine pretty well put back together and I found that I have one valve tappet that is stuck. Any suggestions? I want to here her running this weeken,
Thanks,
Tony
Tony (A2, MI)
05-22-2006 04:38:34
 Re: F20 Valve Tappet in reply to Tony (A2, MI), 05-19-2006 10:23:33
Heat did the trick. Thanks guys!
Janicholson
05-19-2006 21:25:33
If it is up, and not on the cam, patient tapping, and heat as described below is the key. If the cam is up on that lifter tapping will only break things. Make sure the other valve is fully open on thatcylinder, or that it on compression TDC on that cylinder befor messing with it. Been there,
JimN
russ hamm
05-19-2006 15:25:25
tony, as the cowman said it takes patience and penetrant. we have heated the lifter guide at the bottom through the side holes and then worked the guide down with the pushrod and up with the cam. with one lifter this may only take a couple of hours of staedy work so dont worry, you'll make it to the show. getting in a hurry just makes me break stuff and cuss too much. good luck. russ
Nebraska Cowman
05-19-2006 12:22:11
WD40 patience and perseverance. I'll email you a pic of the oil trougth.
third party image
Even bad boys are just as good as they can be
Tony (A2, MI)
05-19-2006 12:39:39
 Re: F20 Valve Tappet in reply to Nebraska Cowman, 05-19-2006 12:22:11
Hopefully I do not suffer from a damaging lack of patience. My local show is in two weeks and I hope to have it ready.
There certainly is no easy way to grap on to the tappet, about all I can do is apply encouragement to the pushrod(?), which I hat to do too much of.
Thanks,
Tony
