Help! With Super C brake job
BillWV
05-19-2006 17:19:51
YTers,
How is the bull pinion bearing retainer removed? I have the parts manual and the I&T book and neither one is much help. I need to replace the seal on the bull pinion/brake shaft. Got the cover and brake assembly off, now what?
Thanks,
Bill
BillWV
05-20-2006 19:22:03
 Got it! Thanks, guys. in reply to BillWV, 05-19-2006 17:19:51
I gently tapped with my 2-lb shop hammer, and gingerly pried with a 3-ft nail puller. :-)
Actually, ground some screwdrivers thin and tapped them in sequentially until it broke loose. It was the center where the o-ring is that was holding it so tight. I assume that the notches around the perimeter are for a gear puller? Didn't have one handy or I would have tried it. Would have to take the wheel off first to have enough room.
Looking forward to getting the brakes fixed now.
Thanks,
Bill
TDK
05-19-2006 20:53:40
 Re: Help! With Super C brake job in reply to BillWV, 05-19-2006 17:19:51
There's an o-ring inside that makes the retainer hard to remove. Pry from opposing sides, it'll come off with some persuasion.
JonT
05-19-2006 18:04:41
The retainer is a tight fit against the housing. I think there are also dowel pins that hold it in place. Carefully pry around it around to remove. I think I remember the I&T manual not being very clear about this part of the procedure when I put a seal in one side of my Super C.
CNKS
05-19-2006 17:44:38
I don't have a Super C, but if it is like the Super H and M, the seal should be on the outside, you just have to carefully dig it out, it won't give up without a fight. -- someone else can correct me if that is not the case.
