Tire pressure suggestions please
Rick/Oasis ID
05-20-2006 05:35:09
I just had the tires on the 300 filled with calcium, they set the pressure at 30 psi. Shouldn't the psi be between 12 and 20 psi? your thoughts please. Thanks as always Rick
Dave BN
05-20-2006 13:37:38
 Re: Tire pressure suggestions please in reply to Rick/Oasis ID, 05-20-2006 05:35:09
The info printed on the side of the tire should tell max psi. Don't know what tire you have but 15 or so sound right to me.
the tractor vet
05-20-2006 07:11:33
He may have left the pressure up as to make sure the bead has seated and forgot to drop the pressure down , i have had some that we have mounted up that did not seat all the way even after letting them down and airing them back up and have left them up for a couple days till they seat then drop them back down also i have found that with the newer tires that running them up around 16-18 lbs that the tread does not buckel when in a hard pull and you get a bit better traction in that range .
F-Dean
05-20-2006 07:06:47
Be sure to have the valve stem at the top when you check them - you will loose less liquid - and use a gauge that can take liquids.
Nebraska Cowman
05-20-2006 06:05:26
Whoa! Yeah, 12 - 14 would be a large plenty.
third party image
Even bad boys are just as good as they can be
