Farmall MD Injection Pump Seal
Matt Compton
05-20-2006 16:34:13
Hey Folks
Well I knew that the oil seals in my injection pump was not good on my MD, ( a little bit of diesel in the fuel) BUT today when I started it diesel was coming out the oil filler on the pump. I shut her off immediatley. I was told there was 2 seals there that go bad. 2 questions. Where can i get the seals? and how hard are they to change? It is an IH pump. Thanks Matt
Geoff NY
05-20-2006 17:34:51
 Re: Farmall MD Injection Pump Seal in reply to Matt Compton, 05-20-2006 16:34:13
I got seals from Connestoga Disel in Pa. 717 872 6685. Unfortunately the seal for the "primary pump" isn"t available for the MD ( A style pump ). It uses packing, they do have the gaskets though. I made my own packing out of 5/16" gas hose. Seems to be holding up pretty well. I have the parts book for all of the IH pumps if you need any numbers get in touch. Geoff
