2 H farmalls
Tom Windsor
05-20-2006 20:28:16
I was offered sight unseen to H farmalls today for $600.00, (delivered) and they were described as follows:
1. Unit one has a cracked block but good transmission.
2. Unit two has a good engine but a bad transmission.
Both have 70% tires. Sheet metal is all there.
I was wondering whether I should jump on this or not...my inclination is yes.
Tom Windsor
05-21-2006 16:41:26
 Re: 2 H farmalls in reply to Tom Windsor, 05-20-2006 20:28:16
Thanks for your ideas. I jumped on them and had them trucked in here today. I even think I can fix the cracked block..... .
Tom
John M
05-21-2006 12:58:01
Reminds me of my 41 M.Old guy got confused on what was wrong with which tractor.We tore down a perfectly good M,which only needed a clutch,to rebuild one that had a cracked block and busted 3rd gear.I learned my lesson!
Steven@AZ
05-21-2006 07:33:10
Usually that kind of money buys you 1 H Farmall with a cracked block and bad transmission... but you don't know it until you get the engine running.
JUMP ON THAT DEAL!
old
05-20-2006 21:47:12
Shoot if the rear tires are that good you could brake even just by selling them. In my area you can't find a good used tire thats the right size to fit an H or any other tractor that uses that size tire
Farmer Bob
05-20-2006 20:31:39
If you decline, I can send you directions to the delivery person to my place. Sounds like a great offer to me. I don't see how you could go wrong.
tn terry t
05-21-2006 04:14:50
 Re: 2 H farmalls in reply to Farmer Bob, 05-20-2006 20:31:39
you cant even find one junker around here for 600 dollars you better start jumping oh! tell me again where they are
KRUSS
05-21-2006 06:40:34
 Re: 2 H farmalls in reply to tn terry t, 05-21-2006 04:14:50
You better get them bought. I could sure use the seat assembly off one of those.
