H clutch help!
pete_5959
05-21-2006 08:28:41
If I let my H sit for more than a day the darn clutch sticks to the flywheel. It will not break loose unless I pull it. Anyone else had this problem and fixed it short of replacing the clutch disk? And if the clutch disk has to be replaced is this possible without splitting tractor? Thanks....
Pete in NC
Al in Mn
05-21-2006 14:38:00
 Re: H clutch help! in reply to pete_5959, 05-21-2006 08:28:41
You do not have to split the tractor to replace the clutch. Drop the belley pump and you can get at it through the bottom.
Janicholson
05-21-2006 11:03:14
Block the clutch pedal down with a piece of wood. This will be a remedy till it gets a new clutch.
I've seen tractors with a strap hinge attached to the platform and a string to pull it up into place to hold the pedal down when not in use.
Good luck, JimN
