what oil do you put in a td340 with a d166 diesel
joeely
05-21-2006 12:20:59
What viscosity oil do you put in a d166 engine? Is it 15w40? I have a gasser but bought a diesel that I am going to part out, but I want to change the oil.
Haas
05-21-2006 14:20:29
 Re: what oil do you put in a td340 with a d166 die in reply to joeely, 05-21-2006 12:20:59
I had a TD-340 for a short time. I beilieve the manual said to use 30 wt oil. However, I used 15W-40 diesel service oil in it. Worked fine. Engine is same as in Farmall 340 diesel tractor which is more common than the crawler.
