H STEERING SECTOR OIL
James C. Newton
05-21-2006 15:28:35
What type of oil should be used in the steering sector section of my H?
Roger46
05-21-2006 19:11:41
 Re: H STEERING SECTOR OIL in reply to James C. Newton, 05-21-2006 15:28:35
If you have put new seals in the bottom of the vertical shaft and the steering wheel shaft you can use 90 weight oil, but is the seals have not been replaced since the tractor was new, you either need to change them or do as Danoh suggested and use grease. Roger
Danoh
05-21-2006 15:54:59
Heavy oil or grease. Since this tends to leak, I use grease. Just pack the bearing with grease before you install it.
