wheel wobble
donald schnuppe
05-21-2006 18:18:21
i have a h farmall and the wheels wobble. does anyone know how to stop that? Thanks don
IA Roy
05-22-2006 22:32:07
 Re: wheel wobble in reply to donald schnupper, 05-21-2006 18:18:21
A couple weeks ago on this forum, someone suggested letting some air out of one of the front tires, no cost. The flatter tires drags enough to keep it from wobbling. I think someone else suggested shimming the between the post and the pedestal to add some castor to the front end. We had an M with a wide front, power steering and a loader on it in the 70's that would lock up sometimes with a load and sometimes with nothing in the bucket. Replaced the steering post bushing and it didn't help. It was probably in the worm and worm gear box. Ended up trading it off that way.
Aces
05-22-2006 05:02:01
Donald If you mean the front wheels then go through the steering. could be many things or just 1 or 2.
Kevin Hood
05-21-2006 22:21:11
My Super M wobbles also. The gears look good, but the top bushing on the pivot shaft is worn allowing play in the gears.
Kevin
