M Paint
newpuller
05-21-2006 19:02:30
which color is an M painted? The website lists to red colors, IHC Red 7410 Dulux made by DuPont and Red TP110 made bu tisco. Which is correct? Or are they the same color just different numbers? Thanx
Bob
CNKS
05-21-2006 19:42:05
 Re: M Paint in reply to newpuller, 05-21-2006 19:02:30
I don't think DuPont has Dulux any more. The 7410 code (matches IH 50) applies to all DuPont paints, from Nason acrylic enamel/acrylic urethane through Centari acrylic enamel through Imron polyurethane. Any of those will be immeasurably better than Tisco. Also more expensive, particularly the Imron, which is as good as it gets. If you don't have to have the highest quality paint job, the 2150 sold by Case IH is an acrylic modified alkyd enamel, less prone to fading than Tisco, and should last a few years. I am basing my estimate on it's chemistry, I have not used any. 2150 is technically the wrong color for the letter series as IH did not begin using it until 1961, but a lot of people use it. I don't think the 1949-1961 colors (1102b and 201) can be mixed any more, I'm not positive on that. The Dupont code for 2150 is 96766, PPG code 71310. PPG code for IH 50 is 70019.
Newpuller
05-22-2006 08:29:48
 Re: M Paint in reply to CNKS, 05-21-2006 19:42:05
Thanx. That answers my question.
