Question about adding hydraulic pump to M?
unioncreek
05-21-2006 19:18:05
I'm thinking about adding a hydraulic pump via a pulley on the crank and a V belt. Will a Charlynn orbital motor work? If not what kind of pump can I use and how many gallons per minute?
Anyone have a instruction sheet made up on this.
Thanks,
Bobg
Steven@AZ
05-22-2006 02:56:00
 Re: Question about adding hydraulic pump to M? in reply to unioncreek, 05-21-2006 19:18:05
Do you have a local hydraulic supply company? If you do, check with them about a pump that can handle the side-load of belt tension.
If not, you can go to this web store and choose to enter the parts room and look under Cross manufacturing for a pump like mine. Mine is the 15 gallon per minute pump and it handles the power steering and any implement nicely.
You will want at least a "B" section belt and the largest pulleys you can fit in order to transfer enough power. I get about 1000 psi out of mine before the belt slips. For comparison, the belly pumps put out around 8 GPM at 800 psi, the Super M live pumps will do 12 GPM at 1200 psi.
I had a good machine shop to work with to make the custom pulleys out of solid steel, along with a mounting plate for the pump, etc. It will be easy to add the pump to an M, mount on the carburetor side of the engine - and you have a lot more room between the crankshaft and front bolster casting compared to an H. I have to take out all the bolts and move the bolster forward to change drive belts now.
third party image
third party image
third party image
