Super H H engine question...
Jugger
05-22-2006 17:45:57
I am currently restoring a super H And was wondering what the difference is with the engines??? I assume pistons is the difference??? The only thing i got with the Super H was the block...I was wondering....Can i use the crank,rods,pistons head Etc. from my parts H on the Super H block?? Or is there something different??? A buddy of mine has a brand new rebuild kit for a H he was going to fix up and he says he will sell it to me cheap So i was just wondering if i could use all the regular H parts on my super H block....
Thank you
Jugger
05-22-2006 21:30:30
 Re: Super H H engine question... in reply to Jugger, 05-22-2006 17:45:57
Ok well what if i rebuild the engine from my parts H will that all fit on the super H with no problems??? The engine should all bolt in the same right??
Nat 2
05-23-2006 05:10:24
 Re: Super H H engine question... in reply to Jugger, 05-22-2006 21:30:30
Yes, it will bolt right in.
If you have, or want, live hydraulics, you either need to be rebuilding an engine out of a 1950 or newer H, or you need to use the timing gears and front cover for a 1950 or newer H or Super H.
It will still bolt right in with the old style front cover, though.
Dave Slater
05-22-2006 18:53:58
As long as you have bearings to fit the size crank your using ( 2 size standard journals were used)everything will work except H pistons and sleeves won't fit SH block.
MJF
05-22-2006 18:32:37
Yeah pretty much everything is different
