Head Cast # 8574
newpuller
05-22-2006 21:33:19
I found the head cast number under the valve cover. It is 8574DC. Is this the same as a 400 head? Some of the parts places I have seen list this cast number for the 400 gas motor. I still have found the cast number on the block. Maybe I will when the machine shop is done.
randy hall
05-23-2006 13:46:07
 Re: Head Cast # 8574 in reply to newpuller, 05-22-2006 21:33:19
400 gas head is a 362174. the 8574 will flow a little better than a 8060 head but they are the same combustion chamber. the 362174 head has a smaller combustion chamber.
Szrachnor
05-22-2006 21:55:34
This is what my parts book has to say about it:
8574DCX Cylinder head with studs and valve guides (Will work for 8060DD) (Gasoline) (S/N FBKM 41346 and up)
the "X" at the end of the part number means it comes as an assembly (valve guides and studs included, no casting number will ever have an "X" on it.) 8060D is the standard M gasoline head that most people look for when there kerosene or distillate head cracks or they just want to raise their compression from 4.5:1 to 5.65:1. So it looks as though you have the proper gasoline head for your machine.
Szrachnor
newpuller
05-22-2006 21:34:16
 Oh yeah in reply to newpuller, 05-22-2006 21:33:19
my tractor is an M.
