Help identifying...
Adam Cox
05-23-2006 13:58:30
I am looking to purchase what I think is an M from a neighbor. There is no serial number tag and I was hoping to get some help on how to figure out exactly what year/model it is. Thanks
Phil Auten (TX)
05-24-2006 08:06:47
 Re: Help identifying... in reply to Adam Cox, 05-23-2006 13:58:30
One way is to check the engine code on the side of the block just behind the carb (I think, I haven't looked at mine in a while). It should read C248 for an M or C264 for a Super M. The other way is the rear tires. An M/Super M would have 38" rear tires.
Phil
captaink
05-23-2006 14:16:54
Check out the tractor photos on the tree to the left for at least the model. Then there are casting codes in the format of 1 1 X (number, number, letter) on the major castings. These codes give the dates the castings were made.
Posting picture here helps too if you know how...
