706/1206 3 point
Tim Mckean
05-23-2006 17:24:23
Can someone tell me if the 3 point hitch parts off of a 1206 will bolt on to a 706 in place of the fast hitch?
A parts book would go a long way here if I had one!
Thanks
Harold H
05-24-2006 05:11:00
 Re: 706/1206 3 point in reply to Tim Mckean, 05-23-2006 17:24:23
Like Jim J said, it can be made to work but everything from the rockshaft to the torsion bar will have to be changed, including, I believe, the top housing. Cat III parts on 1206 are a lot bigger than Cat II parts on 706/806. Personally, I don't believe it would be worth the expense involved. You will be much better off to find a donor 706/806.
Harold H
ejr-IA.
05-23-2006 20:51:26
It will work.
Jim J
05-23-2006 20:04:39
The 706 3pt is a category two hitch and the 1206 is a category three hitch. The rockshaft and the load control shaft off of the 1206 is a lot bigger. It can be done but you will have to change a lot of parts.
Allan In NE
05-23-2006 18:51:31
Hi Tim,
Never owned either of those models, but I'll just betcha that she'll bolt right up since they are both large chassis outfits.
Allan
