H Farmall Need information
Tom Windsor
05-24-2006 10:12:02
Does anyone know:
1. If sleeves are available for an old H..suspect early 40s 3 3/8 in hole. If so where.
2. How to translate the casting markings to show date of Mfg?
Tom Windsor
CNKS
05-24-2006 17:13:40
 Re: H Farmall Need information in reply to Tom Windsor, 05-24-2006 10:12:02
V was not used, Although a person I consider credible says he has see V, but in general, no. U and W were both used in 1951. With the * representing what appears to be a cast in screw head the format is Day*Month*Year.
RustyFarmall
05-24-2006 13:27:08
Sleeves, pistons, rings, bearings, valves, and just about anyting else you might ever need are readily available from a variety of sources. In fact, the availibility is so great that you will want to do some camparison shopping and pricing before you buy. The casting codes are by day, month, and year, the year being represented by a letter. the letter I is 1939, J is 1940, K is 41, and so on. The letters U and V were not used, and some of the 1947 tractors actually had "47" instead of a letter.
