Super C Compression #'s
neyland86
05-24-2006 13:47:23
Can you give me an idea of the compression numbers I should be getting on my super c?
Thanks
CNKS
05-24-2006 17:04:24
 Re: Super C Compression #'s in reply to neyland86, 05-24-2006 13:47:23
125 new, as noted in the link--see tune up in the link. Spread between the cylinders is more important than the actual compression, they should be within 10%. If it runs ok and does not use excess oil, you are ok. IMO you will be down substantially in power if they are below 90.
