LB Engine
Anderson
05-24-2006 16:42:49
Recently bought two IH LB stationary engines. One has a throttle lever behind the flywheel and the other does not have a lever or the notches behind the flywheel. Did older ones not have a lever there?
Anderson
05-24-2006 18:05:59
 Re: LB Engine in reply to Anderson, 05-24-2006 16:42:49
The tag is missing from the one without the notches.
Steven@AZ
05-24-2006 16:47:06
I cannot tell you for sure, but every LA and LB engine I have seen had a throttle lever and the notches.
What is the serial number and data from the tag on this engine?
JT
05-25-2006 13:36:11
 Re: LB Engine in reply to Steven@AZ, 05-24-2006 16:47:06
Steve,
I have a 1936 LA that has a non adjustable throttle, it is set to run one speed.
Jim
Steven@AZ
05-25-2006 13:48:40
 Re: LB Engine in reply to JT, 05-25-2006 13:36:11
I'm not sure of the years of my LA engines... they must be newer or have the option of a throttle.
Thanks for sharing the information!
