Been a long, long, road…(long post)
captaink
05-25-2006 15:03:54
Many times I post suggestions for repairing that some of you might think go a bit beyond what is really needed and may tend to be boarder-line fussy. Well, last night I fired up my old backhoe (Case 680CK that I bought used reasonable) with the 251 CID gas engine in it after a FULL out of the chassis rebuild. (It was using about a quart of oil in two to three hours.) Just to prove that I “put my money where my mouth is”:
The overhaul included sleeves and pistons, rings, gaskets, cam bearings, cook out the block, cook out the heads, tear down the oil pump, four valve guides, three new exhaust valves, two new intake valves, plane both heads, polish the crankshaft, STD mains, “.002” under rods, checked the rods, new piston pins and bushings, thermostat, cleaned radiator, new hoses, spark plugs, points, wires, cap, rotor, condenser, pressure tested the radiator cap, and probably some things I’m not thinking about. On top of that I rebuilt six of the hydraulic cylinders on the hoe and loader. WHEW!!!!!
No, you don’t want to know how much this cost (engine kit alone was $1300 without cam bearings). I don’t even want to know what the total is but will have to know at some point. ;<(
Up side; it fired off like it has just been run yesterday and purred like a kitten for the first hour of run-in. :>) Going to set the valves (cold on this engine) today yet and put the loader, grill, and hood on so I can start breaking it in and using it!
You all have a good night…
Janicholson
05-25-2006 16:03:53
 Re: Been a long, long, road…(long post) in reply to captaink, 05-25-2006 15:03:54
Effort is the Prime mover of progress, (missing in 90% of the people I meet). Good results follow.
JimN
Michael Soldan
05-25-2006 15:10:30
Captaink, I want to say congratulations, it takes a lot of work and determination, I hope you enjoy your tractor and it outlasts you! Take care Mike in Exeter Ontario
RustyFarmall
05-25-2006 15:35:38
 Re: Been a long, long, road…(long post) in reply to Michael Soldan, 05-25-2006 15:10:30
Congratulations from also, and if you think maybe you spent too much, just go out and price a new backhoe.
captaink
05-25-2006 19:34:39
 Re: Been a long, long, road…(long post) in reply to RustyFarmall, 05-25-2006 15:35:38
Yeah, I know about what a new one costs, that"s why I put in it what I did. I don"t do that much work yet, but in a year or so I am hoping to be busier.
jal-SD
05-26-2006 06:20:51
 Re: Been a long, long, road…(long post) in reply to captaink, 05-25-2006 19:34:39
Congrats on a job well done. I'm like you, if you can't do the job right, don't do it. Sounds like you did the job right. I'm sure you will have lots of business soon. (My $0.02 worth. jal-SD)
