350 Tach
Doc T
05-25-2006 17:23:14
I saw a tach on Ebay that has 1167 hrs on it. How or can you turn that back to zero So I can put it on my new rebuild for my 350.
Help, Travis
Janicholson
05-26-2006 13:37:31
 Re: 350 Tach in reply to Doc T, 05-25-2006 17:23:14
The tach is sealed up pretty tight. Getting it open (and closed) might be possible but not just to get the engine hours correct. Just put the number down on the records and call it good. (I would also recommend not leaving it in the rain as they eventually loose their seal and degrade. You could seal arond the glass with lexcel clear sealant with a small tip and help save it.
JimN
Doc T
05-27-2006 08:16:34
 Re: 350 Tach in reply to Janicholson, 05-26-2006 13:37:31
Thanks Jim for the help.
Travis
