Rear Rim Question
Elk Farmer
05-26-2006 13:30:27
Will a 10x38 rim off a Farmall M fit on a Farmall H?
I need one rim and I have one lined up but it is off a M
Thanks
Carl from Michigan
Retcol
05-27-2006 11:41:12
 Re: Rear Rim Question in reply to Elk Farmer, 05-26-2006 13:30:27
Is there a fool-proof method of measuring my existing rims to determine the correct size without removing the tire?
CNKS
05-27-2006 13:59:14
 Re: Rear Rim Question in reply to Retcol, 05-27-2006 11:41:12
The width is the measurement from one inside lip to the other, in other words the distance between the vertical surfaces that the bead fits against, not the width edge to edge. Perhaps if you had two people to hold two rulers absolutely straight up and down on the outside while you measure between them, then subtract maybe a quarter inch, or whatever the twice the rim thickness is.
Retcol
05-26-2006 19:21:46
I need to get a different rim for my Super MTA. The tractor has 13.6 X 38 tires on 12" rims. Does that mean I need to get a 12 X 38 rim?
CNKS
05-26-2006 19:54:44
 Re: Rear Rim Question in reply to Retcol, 05-26-2006 19:21:46
My interpretation of the IH parts manuals is that the rim size be no more than 1 inch smaller than the tread width, meaning for a 13.6-38 (12-38 old designation) a 11 inch is adequate, a 12 inch is also ok. My 460 had 15.5's on 12 inch rims, when I finish it I am likely going to use 14.9's, it may have come with 13.6's or equivalent. Because of what I have read on this forum I was surprised to find the 12 inch rims when I removed the 15.5's. They seemed to fit perfectly with no objectionable curvature of the tread, compressing of the sidewall at the rim, etc.
CNKS
05-26-2006 13:59:33
Rims are the same. That rim was designed for 11-38 (12.4-38) tires. Pretty standard on an H.
Phil Auten (TX)
05-26-2006 13:47:58
Yes, it'll bolt on and work. It will be a little wider than the original, but it'll work.
Phil
