300U PTO Noise
jenglin
05-27-2006 03:37:23
I was mowing with a 3pt mower the other day and my PTO started making this incredible noise. I shut it down to see what the problem was and when I fired it back up the noise got louder and it eventually quit working(PTO). I was using the Torque Amp while I was mowing. Do you think this had anything to do with the noise? The noise was coming from right under the shifter in the transmission. It moves fine it just does not engage the PTO any more. Any suggestions would be great. Thanks!
jaseds
05-27-2006 07:54:25
 Re: 300U PTO Noise in reply to jenglin, 05-27-2006 03:37:23
Do you have an IPTO ,if so it is run off the pressure plate of the engine.noise could have been where the splined shaft goes into pressure plate,they will strip the splines if unit was treated roughly.Also look under trans. and see if you have a PTO disconnect lever it may have disengaged the PTO. These are a couple of problems I have found with none working PTO's. get yourself a IT or equivlant manual that shows trans.
John
