the best 6 volt sytem out there
lekander883
05-27-2006 20:54:53
Just wanted to share with all of you about a problem I was having with my charging system. Standard 6 volt. Anyway I ran a direct wire to ground from my generator and put a manual switch near the dash. So now I turn the generator on and off from full charge when I feel the battery needs some juice. So I wanted to let all of you having problems know how my tractors been starting up just like a 12 volt. Yes it may cause me to buy a new battery a little sooner. But that beats hand cracking.
Brownie 45
05-28-2006 13:10:17
 Re: the best 6 volt sytem out there in reply to lekander883, 05-27-2006 20:54:53
Surplus Center has many Ohmite variable resistors for a reasonable sum.
Bob
05-27-2006 21:46:08
If you want to control it manually, you can get a surplus power rheostat of 20 Ohms, or so, and "dial in" the charging rate you want... no need to have full charge, or no charge.
lekander883
05-28-2006 05:44:55
 Re: the best 6 volt sytem out there in reply to Bob, 05-27-2006 21:46:08
wow even better. Is this an auto part rheostat or household dimmer switch. Any idea where to get one or part number? Appreciate the help. Thanks
