656 wheels
Thomas Harvey
05-28-2006 06:33:59
I have purchased a 656 D row crop it has 18.4 x 34 rears on it. the whell is filled in not the spokes like a regular farmall. I plan on changing it over to 13.9's or 15.5's x 38 so I can go down the potato row... What hubs will fit on this, as I want to find some to change this over.
Colorado Curt
05-28-2006 20:28:52
 Re: 656 wheels in reply to Thomas Harvey, 05-28-2006 06:33:59
I can get you half way there. I have one from a 544. The other one was cracked and ended up in the scrap pile.
Allan In NE
05-28-2006 06:40:55
Thomas,
Sounds like someone has installed a set of factory duals in place of the regular wheels?
The "pullers" are always doing this to "loose" weight.
Any wheel/hub/clamp off a 560, 656, 666 or 686 ought to fit, hadn't it?
Somebody will correct me if I'm wrong.
Allan
Thomas Harvey
05-28-2006 07:18:29
 Re: 656 wheels in reply to Allan In NE, 05-28-2006 06:40:55
Thanks for the reply, I don't think they have pulled it and looking at some old lit on the 656's it looks like some of them came with the wide 34 inch tires.. This came of a horse farm a 656 and 544 traded in on a new utility..I hope it turns out okay I have always wanted a 656 I am farming now with a H and two cubs...I sold my MF diesels a couple years ago and miss the hp so I have got what I always wanted the IH 656...I am 52 years old so I figured better get her...
Allan In NE
05-28-2006 07:44:24
 Re: 656 wheels in reply to Thomas Harvey, 05-28-2006 07:18:29
Good for you, Thomas.
Went with my banker friend last week to look at a 656 that he was considering buying and he had asked for my opinion on the old heifer.
Wish I would have spotted it first. Boy! Did I ever want that tractor; just can't get any better than the 656s!
But, me thinks I got too many now. :>)
I agree with ya tho, sure think I'd get those fat tires off of 'er; think a 14.9 or a 15.5 X 38 would be just perfect. Good luck with the find!
Allan
migraine
05-28-2006 08:57:04
 Re: 656 wheels in reply to Allan In NE, 05-28-2006 07:44:24
The axles from 400, 450 and all those that Allan mentioned are all the same diameter, You should be able to keep those hubs though since the 9 bolt pattern is the same on all pressed wheels be it 34 or 38. Just look for a set of 14 x 38 inch pressed wheels and mount the 14.9 or 15.5 tires on them and you can keep the others for spares. The 14 pressed wheels usually run about 200 a pair around here.
