H transmission and pto seal
Brian in SC
05-28-2006 18:38:35
Just got 48 H with a leaking seal where pto shaft enters the gear box need help on how to replace, also need info on weight and amount of oil rearend holds. I believe it's 90 weight correct me if I'm wrong. Thanks for the help. Brian
williamf
05-29-2006 05:24:37
 Re: H transmission and pto seal in reply to Brian in SC, 05-28-2006 18:38:35
90wt is right. Six gallons.
The IH and I&T manuals neither give instructions on replacing the seals, other than to say that the "double leather seal should be installed with the lips facing inward." I'm sure those seals have been superceded by a more modern style - all the others have. The I&T goes on to say,"Disassembly and reassembly is apparent after studying the illustrations."
third party image
third party image
Good Luck
Wm
