Knowledgeable painters
VAJerry
05-29-2006 03:50:07
third party image
are these guns worth hauling home?
VAPER 3-Piece Spray Gun Kit
Versatile spray gun kit includes 2 guns for different uses. One for lighter coats such as high-quality base or clear-coat applications. One for heavier applications using primers, for surfaces and filler. Includes locking pressure regulator with gauge and 1-liter aluminum gravity-feed paint cups. One for heavier applications using primers, for surfaces and filler. Includes locking pressure regulator with gauge and 1 -liter aluminum gravity-feed paint cups.
brainerd dave
05-29-2006 05:15:10
 Re: Knowledgeable painters in reply to VAJerry, 05-29-2006 03:50:07
I've got them and I like them. Same guns, different tips. I used one to paint the tractor and the other I keep for finishing cabinets.
El Toro
05-29-2006 03:57:29
You will like those HVLP guns. You don't have the overspray as with the old conventional gun. They do require an air compressor that will supply 10 cfm's or more. They use a lot of air.
Hal
KRUSS
05-29-2006 06:49:49
 Re: Knowledgeable painters in reply to El Toro, 05-29-2006 03:57:29
What kind of a mask, etc. should a person have to go with that sprayer?
CNKS
05-29-2006 14:22:56
 Re: Knowledgeable painters in reply to KRUSS, 05-29-2006 06:49:49
If you use hardener, supplied air; no hardener, charcoal. Do NOT use a dust mask.
El Toro
05-29-2006 09:16:33
Most of the paints being used today require a supplied air system. Some are on Ebay for sale.
Hal
sammy the RED
05-29-2006 08:02:50
It would depend on the type of paint and where you were painting.
