HELP: flange key removal
windyville
05-29-2006 06:50:00
1947 'B' farmall.
Trying to remove a transmission shaft flange key. Heat and hammer have not helped. any suggestions? (shaft is still in transmission housing)
john *.?-!.* cub owner
05-29-2006 20:09:00
 Re: HELP: flange key removal in reply to windyville, 05-29-2006 06:50:00
not sure what you are calling a flange key, but if it is waht I call a Woodruff or half moon key, I recently had a similar problem on a touch control pump. I finally took it to a local machine shop, and after he fought it about 15 or 20 minutes, he welded a small nut to the key so he could get a better grip on it, and it came right out.
