Plowing with 350U
Dan Warack
05-29-2006 18:45:51
Can someone tell me how to set the fasthitch on my 350 Utility in the float position. I want to use my fasthitch plow,any help would be welcome. Thanks Dan
Dellbertt
05-30-2006 15:01:22
 Re: Plowing with 350U in reply to Dan Warack, 05-29-2006 18:45:51
To expand on my response, I have always plowed with a trailer type plow with my 300U but it seems to me that a fasthitch system will go deeper in the "float" setting as the ground allows but it could also go way deeper than needed. And in the hard ground the double action setting could force it down to where you want it.
Dellbertt
05-30-2006 14:56:44
Im not exactly sure what you mean but if I am reading you right, set your remote valve to the single action position then leave the lever in the down position. That will let the implement seek its own level.
The single/double action switch is on the front of the front remote valve on the right side of the seat.
