H separation Anxiety--Help
Tom Windsor
05-29-2006 21:26:12
I need to get a motor off an H. I have the front wheels out from under it...The railings are off. There were 4 bolts on each side through the base of the rails--they are of course out. I cannot see anything else holding it on there? I see an alignment pin...what am I missing?
TW
Pappy
05-29-2006 21:50:55
 Re: H separation Anxiety--Help in reply to Tom Windsor, 05-29-2006 21:26:12
If my memory is working, take the starter off and see if there is a bolt back in the hole that holds it together. Seems that is what we had to do. It's been a while.
kfox
05-30-2006 01:20:04
 Re: H separation Anxiety--Help in reply to Pappy, 05-29-2006 21:50:55
Yes, there is a bolt inside the starter hole. Don't overlook the one on the other side sticking out of the bell-housing. ken
Tom Windsor
05-30-2006 02:45:36
 Re: H separation Anxiety--Help in reply to kfox, 05-30-2006 01:20:04
Thanks
I will check it out this morning.
TW
Tom Windsor
05-30-2006 03:16:32
 Re: H separation Anxiety--Help in reply to Tom Windsor, 05-30-2006 02:45:36
I went out there and pulled the starter this smorning...and yep, there is a bolt in there, and one on the left rear side also.
Thank you very much.
TW
