Type of oil for belly pump
Illinois Farmal
05-30-2006 06:26:40
I have a 53 Super M with a M&W live pump and a 46 H with a standard belly pump. The manuals say to use regular 30wt oil (depending on temperature) but I hear of others using hydraulic fluid also. In all of your experiences, which is best? From time to time I have a loader mounted on the Super M but usually just use the lifts with single acting cylinders on implements.
Nat 2
05-30-2006 08:30:49
 Re: Type of oil for belly pump in reply to Illinois Farmall, 05-30-2006 06:26:40
You've got to resist the urge to succumb to irrational fears and oil snobs that tell you that the world will end if you use the "wrong" oil.
Hy-Tran or compatible hydraulic fluid works.
Straight 30W works too.
MagMan
05-30-2006 06:31:09
Use what ever you want just make sure its non foaming. I use the cheap hyd fluid from Sams club in my belly pump. I have used 30wt, 20 wt, 10 Wt,Non Detergent, Dertergent, No difference, Now in the M&W pump I would use 30 if it leaks into motor. Or Hydrolic if it doesnt. What ever you can find in the belly though. SORRY SO LONG
