200 Temp?
Walt La
05-30-2006 15:02:52
What is the correct running range for a Farmall 200, after running it hard for about an hour? I ran mine today for the first time, I was using it for mowing. The temp. gauge got up to about 160- 170. I got off and felt the block and it was really hot, the head too. is this normal? I got fresh coolant in it and can see the water moving through the radaitor. Walt
CNKS
05-30-2006 17:06:17
 Re: 200 Temp? in reply to Walt La, 05-30-2006 15:02:52
If you can hold your hand on it it's too cold. You have a pressurized system and antifreeze, both of which raise the boiling point well above 212. Sounds normal to me.
Janicholson
05-30-2006 17:04:08
Your tractor should run at those temps. It (more than likely) has a thermostat that restricts water flow until that range. Feeling the engine can get you burned! Your car engine probably runs 10 degrees or more hotter. JimN
