Farmall 230 tire question??
t.r.y.
05-31-2006 07:11:09
I was wondering if 13.6 -36 would be 1 size over stock?? thanks in advance.
CNKS
05-31-2006 13:43:28
 Re: Farmall 230 tire question?? in reply to t.r.y., 05-31-2006 07:11:09
Most common tire size would be either 9 (9.4) or 10 (11.2). Considering the size of the tractor and it's intended use, 11.2's are fine. Next size up is 12.4, more of an H tire. 13.6's are overkill for the C thru 230 unless you are into pulling. The tire circumference is too large, which leads to increased ground speed and accompanying loss of power, for the usual tillage operations.
Wayne Swenson
05-31-2006 10:00:23
Yes.
