Super M differences
Cactus Farmer
05-31-2006 08:44:41
Well..... I found a Super M....$1000 with fair rubber....What are the differences between an "M" and "Super M". This one was made in Rock Island. Sure is bigger than my VAC.
Dave Slater
05-31-2006 12:10:12
 Re: Super M differences in reply to Cactus Farmer, 05-31-2006 08:44:41
There were changes made to M and SM tractors durring production. Just taking from the late M made to the early SM most of the changes on SM were a 1/8 inch bigger engine cylinder bore, 2,3,4 and reverse gear ratio change along with bigger diametter counter shaft where those gears press on, Carburator choke lever moved to right side of carb and number change for carb.Grill emblem and mount holes. A 3 core radiator may have started with first SM or little earlier or later,not sure on that.From earlier M to later SM there's more Changes.
ihc49er
05-31-2006 12:01:15
I may as well add some too: seal beam lights,IHC logo on grill.
Wayne Swenson
05-31-2006 09:58:53
Disc brakes, live hydraulics, & live PTO were available plus battery box is under the seat.
David Kronwall
06-01-2006 03:06:12
 Re: Super M differences in reply to Wayne Swenson, 05-31-2006 09:58:53
Wayne...I believe the battery box was under the seat on the Stage II Super M. On the Stage I SM models, it was behind the engine. I think I'm correct. I have a Stage II.
David
CNKS
05-31-2006 13:32:45
No live PTO until the SMTA.
Andy Martin
05-31-2006 12:17:21
Was live PTO available prior to teh SMTA?
captaink
06-01-2006 12:17:29
 Re: Super M differences in reply to Andy Martin, 05-31-2006 12:17:21
Not from the factory.
ih 650
05-31-2006 08:57:00
The super M has a bigger engine and a faster 4th gear.
