m tran oil seal
dadjohnson
05-31-2006 18:40:34
how to get to seal after seperation. pictuers or a blowup may help.
Wayne Swenson
05-31-2006 21:04:24
 Re: m tran oil seal in reply to dadjohnson, 05-31-2006 18:40:34
Both transmission drive shaft & PTO drive seals are located behind the belly pump.
Remove the pump & the PTO seal is right there where the pump drive connector was located. Put the transmission in reverse & lock the brakes. Use a bar or pipe wrench to unscrew the drive lug, lefty-loosey. Remove the 3 cap screws & the housing comes off with seal attached. Replace the seal & gasket, replace the 3 cap screws, screw the drive lug in, righty-tighty, & you are done. Some oil will leak thru the bearing while you are replacing the seal.
Transmission drive is similar but you must remove the drive shaft coupler to get at the seal. Tip: when the nuts are off the tapered bolt, hold the coupler drive with a pipe wrench & turn the tapered bolt to loosen. Don"t try to drive it out or damage will happen.
Good luck.
