super a alternator bracket
Bobby in SC
06-01-2006 17:33:24
Is there a special bracket made for the alternator when changing from generator to alternator on the Super A, or do you rig it the best you can? I have searched for such a bracket and can't locate one. Any help appreciated.
IH fan
12-31-2009 06:26:12
 Re: Checkrow planting and cultivating in reply to LenNH, 12-30-2009 15:45:45
[quote="LA in WI"](quoted from post at 00:59:43 12/31/09) Picture this scene with wire-checked corn:
Just before sunset.
Clear skies.
Slight breeze.
Corn about 6-10" high.
Freshly cultivated.
You are looking from east end of field, with sun glistening off (or thru) the leaves.
You can see all kinds of geometric rows, at many angles.
Beautiful. Just beautiful.
It sure was... although Dad quit check-row planting by the late '40s, I still remember seeing it well into the '50s, at least in NE Iowa. I know Dad never used check-row after going to a mounted planter on the C, I think in 1950, but it had the roll of wire with the planter. When Mom left the farm (mid-'90s) there was a very nice pull type 2 row IH planter left in the barn with the wire and it didn't look like it had ever been un-rolled or the stakes pushed in the ground.
Hugh MacKay
06-01-2006 18:12:24
 Re: super a alternator bracket in reply to Bobby in SC, 06-01-2006 17:33:24
Bobby: There is no such kit, much to easy to fabricate.
It's quite easy to make if you use the generator mount, just weld 3/16 x 2-1/2 x 6 inch plate on top of the old gen mount. Weld on two tabs with holes for alternator mounting pin. Change the alternator pulley to one of the old V8 GM double pulley. By using the outer pulley, this allows you to position alternator back far enough to clear the front of engine casting, and still tuck alternator in close to block. My alternator sits within 1/2" of the engine block.
Another thing I always do is space those tabs for alternator mounting about 1/4" wider than alternator mount. By using washers you can get the belt true. If you want a photo send me an e mail, I think I can find you a decent close up. It may be 130 or SA but they are both the same.
