966 pops out of gear
dozernmike
06-03-2006 18:19:19
My 966 keeps popping out of 2nd gear. What could be the problem
the tractor vet
06-04-2006 07:52:58
 Re: 966 pops out of gear in reply to dozernmike, 06-03-2006 18:19:19
The problem is probably a broken shifter roller or a woren shifter fork . Not a fun job to get to as the fuel tank and dash support must come off to get to it , sure hope ya don't have a cab on the tractor .
dozernmike
06-04-2006 09:31:16
 Re: 966 pops out of gear in reply to the tractor vet, 06-04-2006 07:52:58
No there is no cab. Seems to be extra play in the shaft that goes down into the transmission. Other than that all the linkage is tight.
the tractor vet
06-04-2006 10:06:46
 Re: 966 pops out of gear in reply to dozernmike, 06-04-2006 09:31:16
Yep. the problem is down under the range cover , as to what it is don't know for sure till the top cover is off and ya start looken . So ya need either a cherry picker or a over head hoist to remove the fuel tank and dash support . lost of wires and lines to remove along with all the hood sheet metal plus draining the coolant so ya can remove the temp probe . And most of the time the fuel tank is near full and is wise to drain it for easier handeling. Having a parts break down helps to find is there are any rollers missing if ya have never been in one before or the spring is missing on the detent. I have to pull the one on the 1066 one of these days as it has a broken roller on her and first is our problem gear . You have to hit it just wright to get it . That was all rebuilt 8 years ago but things do break as nothing lasts forever.
